VAT Security System, HELP !!!!
Old Oct 22, 2000 | 01:45 PM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Transmission: 6 Speed
Hi All,
I haven't been tot he new site in a while, it looks good. Anyway, my problem is that I cannot start my car. Every time I try and remote start it or use my key I cannot. The security light on the dash stays on. I wait the 3 minutes your supposed to and try again and still nothing. Is there a way to bypass or disable this stupid feature. It really is getting very annoying. !! Thanks in advance to all reply.
John
Brakes.......In My Dreams They.....DO NOT exist !!!
Old Oct 22, 2000 | 07:25 PM
Andy89RS's Avatar
Read the article on VATS malfunction diagnosis and repair I wrote for the tech resources section. That will help you with the most common problem with VATS. https://www.thirdgen.org/newdesign/tech/vats.shtml
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Nov 25, 2000 | 04:32 PM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Thanks a million Andy, that info was extremely helpful as hell.
John
Old Nov 25, 2000 | 04:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is another tech article, however it does not endorse bypassing it. Check it out. PassKey.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Nov 25, 2000 | 04:42 PM
camaro 22's Avatar
i had the same problem, however my vats was already bypassed due to my aftermarket alarm. it turned out to my my neutral safty switch either went bad or needed adjusted.
junior419
Apr 7, 2025 11:35 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
Winchester1094
Sep 15, 2015 09:48 AM
