327 trans am?
Old Sep 30, 2003 | 08:08 PM
firebird frenzy's Avatar
327 trans am?
is it possable and if so how hard? Someone gave me a good deal on a approx 300hp 327 and i was wondering how hard it would be to bolt up to a thirdgen?
Old Sep 30, 2003 | 09:35 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
If you have a v8 in there now its a direct bolt up
EDIT: Forgot to mention, I don't know anything about later model 1pc seal blocks but I guess the tpi manifold would bolt up. be careful, this dude my be trying to funk you over. get the block numbers and look them up to make sure its legit.
Old Oct 1, 2003 | 01:33 AM
iroc22's Avatar
You will need a new flywheel/flexplate for the correct rear main seal depending on what year TA you have.
300hp gross is roughly 220hp net, which is what all the new cars are rated at (post 1973)
Trying searching the motor swap board, tons of useful information.
Old Oct 1, 2003 | 05:33 PM
is it worth it
alright he wants 500 for everything minus the carb it came out of a freakin C-6 dumb truck and he had it in his 4/4 truck and said its to torquey for his taste.......i'm guessing he's just messin around with things cause he works at a junk yard it prob has a chit load of miles on it and i'm kinda cautious about him sayin its putting out the power he says it is? but for 500 buxs and running smooth is it worth the gamble?
Old Oct 1, 2003 | 06:20 PM
rjmcgee's Avatar
Walk away. If it really came out of a dump truck then it is nothing you want in a performance car, unless you plan to go though it. $500 will buy you a pretty good 350.
Old Oct 1, 2003 | 07:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i'd walk away personally, if he works at a junkyard he probably pulled it out of somethin and has no idea of the actual mileage or anything.. plus for 500 around here you can get a decent rebuilt 350 from a machine shop... 350's have more cubes = more potential for power.
Old Oct 2, 2003 | 05:38 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
+ if its really a 300 hp 27, it'll have heads suitabled for leaded fuel. Won't last long with no lead. I'd run away from that deal. I'd buy a 350 block for a 100 and put the rest tords the rebuilding of it, as a 383.
Old Oct 2, 2003 | 05:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats not a big deal really. You just have to have hardened valve seats installed, and its good to go on unleaded gas.
But everyone else has a good point. For the same money, you could get an equally (if not more) healthy 350. A 350 will always make more power than a 327 will, and more reliably too.
It's probably a small journal block too, so its gonna be really hard to find rods or a crank for that engine, not to mention its not going to be as strong as the 350, which had large journals.
Hawk312
Aug 22, 2017 08:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Leggman1
Aug 6, 2015 04:15 AM
