V6 car rearend question...
Old Oct 1, 2003 | 11:45 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Buddy just purchased a 84 berlinetta. It was originally a v6/5 speed car. Im assuming the tranny is a v6 tranny but we are not sure it now has a 350/5 speed combo.
Would the rearend have 3.42 gears in it? I thought most v6 cars did but I am not sure.
Old Oct 2, 2003 | 12:00 AM
bes217's Avatar
The only way to be positive of the rear ratio is to check the actual gears. But you could also check the stamp on the rear end.
No it does not have the V6 tranny in it still. The V6 tranny will not bolt up to the 350. So... it has a different one in it now.
Old Oct 2, 2003 | 12:28 AM
Transmission: 4l60e
v6 t-5 will bolt up to a v8 with a v8 bellhousing. I know 2 guys that have done this.
Old Oct 2, 2003 | 05:13 PM
bes217's Avatar
Yes that is true, and thanks for pointing that out. But, and correct me if I am wrong, didn't the v6 t5 use some lesser internal components that would sacrifice the strength and integrity of th ev6 t5. For some reason i was under the inpression that the V8 T5 was a bit beefier.
Old Oct 2, 2003 | 05:48 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The internal gearing makes them more prone to blowing up with an increase in power. And then there is the clutch issue
Pete
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
