Hypertech Fan switch. Where is the fan switch?
Old Nov 22, 2000 | 11:34 PM
simon's Avatar
Recently I purchased a Hypertech fan switch in order to keep my engine a little cooler. I read the directions and it stated that the stock switch is usually located on the passenger side cylinder heat between plugs 1&2 is this correct? This doesn't have anything to do with the temp sending unit in the front of the manifold does it? Please help quick, its getting pretty cold and I don't want to fool around with this in the winter. Thanks!
89 RS V-8
Old Nov 23, 2000 | 06:44 AM
maniacc's Avatar
the fan switch should be located between #6 & #8 sparkplugs, on the pass side above the starter in the cylinder head...
later
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
Old Nov 24, 2000 | 12:24 AM
simon's Avatar
Thanks, I went out today and removed the old one, what a pain. I was installing the new Hypertech switch in the head, and I couldn't get the 7/8 socket on the top of it due to the oil dipstick was too close to it. Have to go out tommoro and buy a 7/8" open ended wrench. Thanks for your help. I assume you installed one of these in your car, what temp rating did you use?
89 RS V-8
Old Nov 24, 2000 | 08:41 AM
Blockhead's Avatar
This is power adder tech?
Old Nov 24, 2000 | 08:42 AM
Guido's Avatar
Car: 2000 Trans Am
im moving to general engine
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
Old Nov 26, 2000 | 01:11 PM
Pat Hall's Avatar
Don't forget to wrap the switch with some teflon tape to prevent leaks!
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
