How to tell
Old Nov 26, 2000 | 11:47 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
How to tell
Hey guys I am looking to buy an L98 from a wrecking yard to rebuild now, my LB9 TPI runs like new so I want to build this engine now while I have no time pressures to complete this project and I can do some other mods during rebuild since time is not a factor so my question is how can I be sure I am buying a L98, any codes, casting numbers, etc. that will tell me.
THANX
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
[This message has been edited by MY87ROC (edited November 26, 2000).]
Old Nov 26, 2000 | 11:51 PM
mtx28's Avatar
get teh vin and put it through the vin decoder on this page... its still here isnt it?
Old Nov 26, 2000 | 11:54 PM
JJ's Avatar
JJ
You may be better off buying a 350 crate shortblock with one piece rear main seal (depending on your future plans of course), then switching your tpi over (bigger injectors and heads of your choice).
87 IROC, 350/5 speed. gmpp 350, vortec heads w/some work, XE268, 1.5rr's, 650dp, rpm intake, MSD ing., ect.
89 formula, L98.
Old Nov 27, 2000 | 12:36 AM
Bort62's Avatar
You can get a Bare shortblock, single rear Main, from Summit for 600 Bucks.
4 bolt, very Nice Block IMO, if you are going to Do a Complete, performance build, this is the way to go.
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Nov 27, 2000 | 06:47 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
hey thanx JJ and Bort62 those are both very good suggestions that i will look into
thanx for your opinions.
