PCV valve air tube
PCV valve air tube
The hose going into the passenger side valve cover....Does it do so with a PCV valve, or simply an "elbow"? I have different heads and valve covers, and I have drilled the hole in the valve cover for this hose, so this is why i ask. Thanks!
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Car: 1990 Formula
Engine: 5.7 liter
well to answer your question...if ya got carb or tbi, the pass side elbow tube from the valve cover goes to the stock air cleaner assembly located on the pass side of the air-cleaner. it is used to clean or recycle the exhaust blow-by coming from the heads going to the throttle.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
I have experience...unfortunatly,its a result of bad judgement.
Car: 1990 Formula
Engine: 5.7 liter
also it is a metal elbow tube that rests in the valve cover and has a small rubber section on the other side that slips on the breather lip on the side of the cleaner.
Omar,
A TPI uses this air supply to the engine directly - there is no PCV valve in the right rocker cover. The only PCV on the engine is on the left cover.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Originally posted by Vader:
Omar,
Omar,
Also, Formula90, his sig says 1989 IROC-Z 5.7L, that means its TPI.
Carb and TBI are 5.0L only (stock, that is)------------------
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Kevin, thanks for noting my sig!
The hose on the passenger valve cover is part of the PCV system, it's just that there is no actual PCV valve on that particular hose, just on the drivers side. Which I know from these guys answering and from just returning from the parts dealer. I have the newer black composite corvette valve covers on my TF heads, and I had to drill a hole for that provision. I just couldnt remember for the life of me if it was just an elbow, or an actual valve there connecting the hose.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Just so that you know, the purpose of that tube is to allow fresh air from the air cleaner to be pulled into the crankcase. The air is pulled in from the vacuum from the PCV valve, then the blowby is sucked into the intake to be burned. On a TPI setup, I believe the inlet goes to the hose in front of the throttle body, and on a TBI/Carb setup, it goes to the air cleaner housing, and hooks to that small filter.
Hope this clears up the operation of the system!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have the same thing and all I did was get a PVC breather cap and then ran a bent molded hose from that to the pipe coming from the throttle body...looks pretty good, a hell of alot better than just a simple tube with an elbow in it..
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
1987 White IROC-Z
700-R4 auto tranny
97,000 miles
KYB's
Flowmaster Muffler
Holley AFPR
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Boush Patinum +4's
Car: 86 Trans am
Re: PCV valve air tube
Hi I was doing a TPI to carb swap and was wondering if the PCV valve on the passenger side was nessacery or if I could just plug it. Also there is a hose that runs on the driver side valve cover that use to go to the throttle body and was wondering if that was imoportant either or if I should just cap that too.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wow, dead thread. Breather both covers or breather one cover or run to air cleaner base and pcv on the opposite side to manifold vacuum.
1992 Trans Am
May 10, 2023 07:19 PM
