Car dies
Old May 22, 2021 | 03:34 PM
Moonlightlady79's Avatar
Car dies
My 86 transam dies when at a light, putting it into reverse. Must always keep foot on the gas to prevent dying. The car is mostly rebuilt with tons of new parts. What could be causing this?
Old May 22, 2021 | 09:38 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Car dies
Are you saying the car dies when you come to a stop at a stop light, or when putting it into reverse?
Does it do this when the engine is cold? Hot? Doesn't matter?
Which engine does your Trans Am have?
Old May 22, 2021 | 10:15 PM
Re: Car dies
Both at a light and when putting in reverse. Only when the engine is warm. It’s a 305 tpi
Old May 23, 2021 | 03:31 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Car dies
Any of a multitude of things could cause that problem; what have you already checked/replaced and thus eliminated as a possible cause?
When the car stalls, what is the fuel pressure, and does the engine have spark at the plugs?
Old May 23, 2021 | 03:34 PM
Re: Car dies
We have replaced the plugs, wires, injectors, fuel filter, fuel pump, ecm, prom chip..,,,,,basically everything. Only thing that is original is the engine and transmission.
Old May 23, 2021 | 06:27 PM
Yeesh's Avatar
Re: Car dies
Idle Air Control system gummed up/not working?
Vortex91
Aug 27, 2024 04:22 PM
Derrick86
Mar 28, 2014 04:40 PM
amyz28
May 6, 2012 06:38 AM
Stratocaster
Oct 8, 2007 10:40 AM
2_point8_boy
Apr 23, 2003 01:05 PM
