heater core??
Old Nov 26, 2000 | 03:08 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
heater core??
ok, my heater core is leaking really bad only when engine is cold. when i first start it in the morning i have a big puddle on my passenger feet area. the leak goes away after im at 130 degrees.. is it hard to replace. ive heard that its a little difficult. thanks for anyhelp
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Eldebrock Headers, 3" Hooker Cat-Back, duel outlet with quad tips.
Mods: 1.6 Proform Roller Rockers, electric fan.
Future mods: X-Ram( Aftermarket Cross-Fire Injection Manifold that proves to have as much power as TPI www.x-ram.com )
Cross-Fire Injection after market chip that says that it will proform like 90's injections.. http://www.turbocity.com/CorvetteCro...ECMUpgrade.htm
Old Nov 26, 2000 | 05:57 PM
Engine: LT1/350 TPI
oh, nevermind. i just did it and it took me about 1 hour to take it out and just 30 min to put a new one in. not that hard at all. Thanks anyway...
RED82TA5.7L
Old Nov 26, 2000 | 09:00 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Tell me more about that CFI setup you have...ever been to the track?
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Old Nov 26, 2000 | 09:32 PM
Engine: LT1/350 TPI
no, ive never been to the track. i have the stock CFI manifold and computer but on a 350 instead of a 305. runs good other then i cant go over 4000 rpm and the idle goes up and down. i went to the dealer and they said the idle problem will be fixed with K&Ns and will help the upper-end problem. i have ALOT, and i mean ALOT of low-end torque. i get to 60 in about 6.0s without going over 3800 rpms. when i get the upper end problem fixed i think i will get to 60 in about 5.5s. I love the CFI. its not as bad as everyone has been saying. and CFI was not made to make TPI look good. they did it because they wanted the low-end torque. they got the disign from the late 60s early 70s duel carb setup. Hope this helps
RED82TA5.7L
Old Nov 27, 2000 | 10:03 PM
Engine: LT1/350 TPI
hey, i just wanted to let you know that today i just added a Corvette CFI Computer Chip and i noticed ALOT more mid-range power. and some more low-end. but it didnt fix the upper-end problem. just wanted to let you know
RED82TA5.7L
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette CFI computer chip.
Old Nov 28, 2000 | 12:11 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Man, that X-Ram setup looks sweet! Too bad there's not that much of a market for it! I wouldn't mind have a CFI car to tinker with, I think there's a lot that could be done with it after putting on the X-Ram!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 28, 2000 | 12:23 AM
Engine: LT1/350 TPI
i just erased the Future X-ram mod because alot of people say they lose alot of their low-end torque. but the CFI is known for low-end torque. id rather bore my manifold then get the X-ram.
RED82TA5.7L
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L CFI computer chip.
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
