Casting Number question
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Casting Number question
Originally posted by noc_81
Anyone know anything about 14022601 cylinder heads? By the design, they seem to be lightweight 305 heads, but I don't know anything else.
Car: 1989 C4
Axle/Gears: 307
IMO there better then 416's, side by side comparison the 601's have advantages with port design. They have less material blocking flow so thier easyer to port. Disadvantage is they have recesed bumps that can reduce flow if not filled or the ports are not taken down enough.
Edit: the 601's are 55cc heads not 58cc like moretec lists them as.
Transmission: 4L80E/4L80E
It's not a big problem. If your 350 has dished pistons, then those heads with port & chamber work, 1.94" intake valves, and a thick head gasket, will provide a compression boost and flow well enough for the 350.
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
