t5 wiring question
Old Oct 4, 2003 | 08:26 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
t5 wiring question
Okay so I have been searching around and havent found an answer, I did the auto to t-5 swap all I have left is the wiring, I think I figured out the reverse lights I have to try them tommorow.
But I cant figure out the nutral saftey switch. I have a pigtailed connector comming off my pedals that is purple and yellow, from what I understand this is normal. But I dont have the same wires comming off of the auto shifter, the shifter has wires that are the same guage that are purple and green, I am assuming they are what I need, do I hook up purple to purple and yellow to green?
Has anyone seen this, I have a 91z28 and the pedals came out of something older.
Old Oct 5, 2003 | 10:58 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
It shouldn't matter which wires you connect. It should be just an open/close switch, so the polarity does not matter. Do a continuity test for the switch operation on both the shifter and the clutch pedal to verify that they operate the same.
open=no start
close= start
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
