distributor
Old Oct 6, 2003 | 08:39 AM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
distributor
I was just wondering where exactly the "distributor wire" is located. Is it able to be reached from under the hood? Do I have to remove anything to get to it? I am thinking that it may be loose which is why I am asking.
Also, when inspecting the distributor for damaged components, what should I be looking for?
Old Oct 6, 2003 | 11:14 AM
ede's Avatar
ede
i think the real question is " what's a distributor wire?" or "which distributor wire?". look for mechanical or physical damage actually as cheap as the parts are you're ahead to just buy nwe cap and rotor and swap them out
Old Oct 6, 2003 | 02:53 PM
rezinn's Avatar
Check between your ignition coil and the back of your distributor. Unless your car stalls, or runs like a bucking bronco, you probably don't have anything loose or disconnecting. You could have a wire pinched under the cap, or something damaged from heat, though.
Old Oct 6, 2003 | 08:14 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
I just replaced the cap and rotor. I am running out of ideas as to why my car is stalling. I read a post (can't remember who started it) and they said that they have tried everything that I have and the new distributor did it. Before I go replacing that I want to make sure all connections are good.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
