replaced heater core sill no heat ??
Old Nov 16, 2000 | 05:24 PM
jeremy7777's Avatar
high guys well i took my car by the shop twice frist time the fixed the heater swicth so the air will blow out the vents or defroster, but i still had no heat, so again yesterday they said they thought it was the heater core, so i took it home and replaced it still not blowing heat, anyone got any suggestions , thanks
Old Nov 16, 2000 | 05:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Heater control valve...
Follow the heater hoses to the valve, check to see if it has vacuum when it should; if it does, replace it; if it doesn't, investigate all the vacuum lines leading to it, starting at that vacuum switch.
Old Nov 17, 2000 | 06:40 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Also did you check your thermostat?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 17, 2000 | 09:02 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
One more thing, it may divert air to the vents, but does it also divert air over the heater core? My digital das car, had a little motor that moved the door, the connector from the door to the push rod was broken, whci had the thing stuck in cold air mode.
Corry
Old Nov 17, 2000 | 10:15 PM
jeremy7777's Avatar
thanks guys for the help, well i changed my thermostat a few months ago, so i know thats not it i hope lol, allso when i put in the heater core i have the same deal with the motorized door, that is working, i had the dash out and held my hand next to the heater core while the car was hot and nothing, so i went to see if the lines going in where hot, well no they are just warm form the engine, now the frist post, the heater value is that in the little plastic tube looking thing,with the one vacum line going into it, and three hoses comming out one to the throttle body, one that goes into the block and one that comes from heater core, i pulled of the vacum line and its not sucking, so im guessing that line is broke or is not supossed to have suction ?, i went by the auto parts store today and ask to see a heater vaule for my car and the guy brought back a metal tube with two ends on it in a sorta t shape with a litte turn on vaule , does that go or is that in that little black box ,im kinda confussed, if nothing else cant i do away with the whole heater vaule and hook up direct so water runs through the heater core at all times, ?????? HELP LOL
Old Nov 17, 2000 | 10:23 PM
jeremy7777's Avatar
ok read frist post again VACUM SWITCH where is that located, the vacum tube from the heater vaule does not have any suction, so when you follow that little plastic tube back it goes into a engine harness down into the firewall but i am getting suction from other places such as cruise controll and all , ???????????/
Old Nov 18, 2000 | 01:04 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
ahhhhh....the fun you could have with a vaccume diagram and some tech manuals,sorry,I'm just being a **** because I really don't know.
Old Nov 18, 2000 | 12:56 PM
Corry's Avatar
Car: 1987 Trans Am
I am not sure where the vac line is supposed to com from. Mine too gets no vacume, and I replaced the console switches, and the heater core, and the heater control valve. Since I never use my cruise control, I found a line w/ vac all the time, and split a line out from that to my heater core. As for can you eliminate the heater control valve, the answer is YES! In fact, they never used to have heater control valves, so you can just directly run the coolant lines. Unless someone here can tell us why we get no vacume to our heater coltrol valves
Corry
Old Nov 19, 2000 | 08:38 PM
daniel dekay's Avatar
im having a similar problem with my heater. mine gives out heat but wont switch speeds. it always stays on the low speed. Have u checked your fan motor? thats what my problem is, and as soon as i play with it for a while im sure ill will fix it.
Old Nov 20, 2000 | 05:13 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Jeremy,
take a vaccum line with suction and plug it into your valve. See if this makes a diference. You can also take the valve off and check it for operation using another cars vaccum or a vaccum pump.
Lastly, you can by pass the valve temporarly as well.
William.
Old Nov 21, 2000 | 11:34 AM
jeremy7777's Avatar
SWEET guys, thanks for the info, yeah today im going to try to split a line off my cruise controll and if that doesnt work then im just going to bypass the heater vaulve thanks guys, man i love this board
Old Nov 29, 2000 | 05:59 PM
jeremy7777's Avatar
well im back guys, guess what still no freaking heat, tried everything as everyone said in the above post, i did away with my heater core and hooked up direct, well no heat, last possibly solution, something stuck in the lines,well today, ran a water hose through the lines, and through the whole clycle through the oil cooler and all, (89 350 l98) anyways, water was going through fine and gushing out the radiator cap, so im stuck anyone got anymore ideas, this whole thing doesnt make since, i can hold my hand next to the heater core while the motor is hot, and still not one bit of heat ????????????????? , everything is hooked up right, had three engine macanichs look at it, they dont know either, ????
Old Nov 29, 2000 | 06:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly where (and I do mean exactly) are your heater hoses hooked to on the end of them opposite the heater core?
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
