High Reving Not Welcome...
Old Oct 8, 2003 | 12:12 AM
WannaBeA350's Avatar
Hello again! Did a tune-up with AC-Delco rapidfire #2 plugs, and an oil change with 5W-30 synthetic blend today. When I put everything back together I took it for a ride and it was reving high, 1000rpm in gear stopped, about 1400rpm in park or neutral. Discovered a small vacuum line I forgot to reconnect to the back of one of the TBs. Hooked it back up and all was good. Went out later, started it and it was fine, but when I got to my dest. it was back high reving again! Grrr, lousy day with my T/A 2day! It was already dark so I couldn't check the lines, but I really don't think anything popped off, it was all on there pretty tight. What else would cause the high RPM??? Thanx guys!
Old Oct 9, 2003 | 09:57 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
have you checked the vac. lines in the light again yet?
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
