Whos running a Big Solid Roller?
Old Oct 8, 2003 | 02:02 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I have a set of solid roller lifters and some evil springs I am considering using.
My question is, How often do you adjust them, and how much of a difference in idle quality is there from a hydraulic roller?
If i went with one if would be in the 230/240 range with as much lift as i can find. Its a daily driver though, and while adjusting rockers isnt hard it is particularly messy and somwhat annoying to do before work every other week.
Or how often?
Old Oct 8, 2003 | 05:22 AM
ede's Avatar
ede
run valves once a year or so, running the valves on a solid cam isn't messy, with same specs there would no noticable differance in idle
Old Oct 8, 2003 | 08:29 AM
Odyssey's Avatar
I have a fairly large one for a street setup and I only had to adjust it once after the initial buildup back in April. Just did a couple of weeks ago actually because they were gettting a little too noisy. Of course if you could afford it, go with a hydraulic roller and be trouble free. That what I would have done... but oh well. Anybody want a solid roller setup ? lol
Old Oct 8, 2003 | 05:34 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Actually thats not bad, once a year, once in a great while, very nice..
I still need a cam pushrods and springs to match... so if you want to get rid of yours let me know. I will probably go for it then, since i have the lifters i cant afford $419 for retro fits.
midge54
Dec 27, 2019 04:14 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
camaro71633
Sep 1, 2015 10:24 AM
Street Lethal
Aug 13, 2015 08:28 PM
BrianI
Aug 9, 2015 11:52 AM
