harmonic balancer
Old Oct 8, 2003 | 09:08 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
harmonic balancer
I have determined that the timng ring on my harmonic balancer has moved (which explains all the trouble with timing I was having!). I will probably never turn the engine over 6500.
Should I go back with a stock" OEM" type or go to an after market type?
Do the aftermarket do any better job in balancing?
Do aftermarket do better job of timing ring not slipping?
ANY advice, experiances or comments will be appreciated
Old Oct 8, 2003 | 10:18 AM
ede's Avatar
ede
aftermarket are better in every way, only draw back is cost
Old Oct 8, 2003 | 10:47 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Some aftermarket balancers are made completely solid, so there's no possibility whatsoever of any sort of ring slip. The balancer on my 302 is solid...the timing is sort of painted/etched onto it. Thing is beautiful...works damn well too.
Old Oct 8, 2003 | 11:48 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Nixon1
What brand do U have? cost and source?
Old Oct 9, 2003 | 11:43 AM
Nixon1's Avatar
I had it installed quite a while ago by a mechanic (didn't have the time to kill tinkering with the new daily driver).....but I'll see if I can't get a hold of him and ask, or if there's a label on the balancer. I'll get back to you if I can.
Old Oct 10, 2003 | 08:44 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
THNAKS!
Old Oct 10, 2003 | 01:16 PM
Nixon1's Avatar
Here ya go:
The company is called Cal Auto Transpeed... Their website is:
http://www.catpep.com
The Part Number for my balancer was HB-302 ("Harmonic Balancer-302 cid" of course). You might give them a call and see what their pricing is and if they have a balancer for your car. If they have a balancer for an externally balanced motor like a 302, I'm sure they'll have a neutrally balanced one for a 305 or 350.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
