Question about Waterpump!!
Old Nov 30, 2000 | 09:10 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Ok, when my car is at idle, and the heater is switched on, it will blow cold air. When my car is at 1000 rpm or above, it will blow hot air. Could this be due to my waterpump is on its way to the grave??
Also, my radiator has a small leak, does the radiator system have to be air tight? Could my problem be due to air being sucked in through the hole and cause some sort of air lock at idle??
I really need help on this one!
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Nov 30, 2000 | 10:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The problem is that your cooling system is so low on fluid that the WP can't throw it high enough at idle to make it all the way to the heater hose fitting.
Fix the leak, fill it up, and it should work fine.
Old Nov 30, 2000 | 11:31 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Thanks, Ive posted this before and no one really answered the question.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
