new motor at the track?
Old Oct 8, 2003 | 06:42 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
how long would you recommend waiting before running a new motor at the track, 500 miles, less, more?
im anxious to see what times im running now, but i don't want to ruin a brand new motor.
Old Oct 8, 2003 | 07:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From http://www.gmgoodwrench.com/crate_eng/startup.shtml :
1. Always put safety first. If your car is on the ground, be sure the emergency brake is set, the wheels are chocked, and the transmission cannot fall into gear.
2. Be sure to check the engine's oil level and prime the oil system.
3. Run the engine between 2,000 and 2,500 RPMs, with no-load on the engine for the first 30 minutes.
4. Adjust the distributor timing roughly by hand for a quick start-up and the smoothest idle possible.
5. Adjust the carburetor settings, if necessary.
6. After the engine has been running for 30 minutes, set the ignition timing (see install ignition section for timing specifications).
6. Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be sure not to use a lot of throttle or high RPMs.
8. Run five or six medium-throttle accelerations to about 5,000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.
9. Run a couple hard-throttle accelerations up to about 5000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.
10. Change the oil and filter with 10W30SG oil and PF1218 ACDelco oil filter (PN 251605610).
11. Drive the next 500 miles normally, without high RPMs (below 5,000 RPM), hard use, or extended periods of high loading.
12. Change the oil and oil filter again.
13. Your engine is now ready for many happy cruising miles.
Step 13, I'd say.
Or, if this is a track-only car, after the 1st time the oil changed.
Old Oct 8, 2003 | 07:50 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say about 500 miles.
evan555222
Sep 20, 2016 02:51 AM
evan555222
Aug 22, 2015 07:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
