Tie arms OOOPS RODS...TIE RODS!
Old Nov 18, 2000 | 01:33 PM
PopaPork's Avatar
Ooops I meant to say Tie Rods....has anyone replaced the Tie Rods? Mine are soo rusted they can't do an alinghment. Thanks again
Old Nov 18, 2000 | 02:16 PM
ede's Avatar
ede
if they're that bad replace the inner and outter as well as the sleeve that connects them. easy job, but you'll need a tie rod seperator aka pickle fork.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 18, 2000 | 02:20 PM
Mo's Avatar
Mo
I'm not sure if this is what your talking about, but if its those piecews that you turn to do alignment, mine were rusted too, when i had to get alignment, they told me they couldn't do it. A little WD40 and like ten minutes later i had em turning just fine.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Nov 18, 2000 | 02:26 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Never underestimate the power of WD40!
Old Nov 18, 2000 | 04:56 PM
PopaPork's Avatar
Hey guys thanks for the help. The Tie Rods are soo rusted it isnt' even funny. MO I tried you WD40 idea awhile back. No luck...but hey never under estimate the power of WD!! I bought the parts today 123.95 for both sides, 2 inners, 2 outters and 2 sleeves. Gonna attempt the switch this friday after Tday. If you see a big mushroom cloud comin from the Direction of NJ. I am having problems :0) Hey Moderator......thanks for the help buddy!
Old Nov 19, 2000 | 11:21 AM
Vader's Avatar
Papa,
When you assembly the new tie rod sleeves to the new tie rod ends, put a liberal coating of anti-seize compound on all the threads. If you are planning to keep your car for more than a couple of years, you'll appreciate it later. Do the same thing on the tapers for the tie rod ends, and the castleated nuts that hold the tie rods in. Torque the nuts to spec, install the pins, and forget about rust.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 30, 2000 | 10:27 PM
PopaPork's Avatar
Hey I just want to let you guys know....the tie Rods went on and off with out a hitch. Took about 3 horus to do both sides and only cost me about 120 bucks. If I can make one suggestion for anyone who decides to tackle this project next......find your self a nice heavy 9 lb hammer. 5 hits with that thing and poof it is off. I tried for about 30 with a regular one....man did I get tired. Well thanks for all the help guys.
Hotrodboba400
Dec 10, 2019 07:07 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Nervous2
Oct 8, 2015 10:53 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
