Crack in the fuel line.
Old Oct 9, 2003 | 05:51 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
one of the fule lines is craked at the base... what can i use to patch it.. im looking for something that the gas wont eat up.
Old Oct 9, 2003 | 05:52 PM
white91Z28's Avatar
Engine: TPI 350
heres a pic
Old Oct 9, 2003 | 09:16 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can find another from a boneyard.
You can cut off the cracked part and flare it using a flaring tool and a tube nut and sleeve and replace the line with aluminum or braided tubing.
Is that the return or the feed line, I can't see?
If it's a return, you can use the slip on ferrule connectors to connect some aluminum or braided tubing.
I wouldn't use any thing like jb weld on it, but that's just me.
Old Oct 10, 2003 | 09:18 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I had that problem... and that piece is about $450 new! I had my entire fuel system replaced... see my sig
I would go the route of replacing it, rather new or junk yard, you don't want to mess with gas!
Old Oct 10, 2003 | 11:00 AM
white91Z28's Avatar
Engine: TPI 350
this is the line that is craked at the base of the tube, where it connects to the big round thing.
Old Oct 10, 2003 | 11:02 AM
white91Z28's Avatar
Engine: TPI 350
I thought about using jb weld... is there anything wrong with using jb weld for this application?
Old Oct 10, 2003 | 11:07 AM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Using JB weld would be okay gas wont eat it up, just remember to let it cure completely i think thats like 24 hours, and remember to clean the surface completely of all contaminants, i would go with the industrial grade, also look at PC-11 it's probbably a little better
Old Oct 10, 2003 | 12:13 PM
Briansz28's Avatar
If its already off the car, bring it to a radiator shop and have them silver braze it-as good as new and it will last longer than a patch.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
z28_AJ
Aug 27, 2015 08:59 PM
kyleb24
Aug 15, 2015 08:24 AM
