Permatex Plenum Air Tubing..
Old Nov 30, 2000 | 12:06 PM
sguy30's Avatar
I am redoing the gaskets for the plenum air inlet piping (after manifold gasket replacement) and am wondering if I should use a sealant on this piping as well. In the past I have just kept them dry.
'87 IROC, 305TPI, 5Sp, , 170K miles, all original except for K&N filter, Vin F
Old Nov 30, 2000 | 02:56 PM
Blade's Avatar
Might wanna explain exactly what you're trying to seal exactly... then we will be able to respond
Old Nov 30, 2000 | 07:40 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
diddo,
what are you referring too?
a gasket set should have all you need anyway.
88 CAMARO RS
87 IROC-Z DRIVETRAIN
305 TPI, 700R4, 3.73s
ported plenum, performance resource chip,edelbrock TES Headers and cat-back, K&Ns, AFPR, rest is stock.
15.0 @ 92.5 (bald tires)
Old Nov 30, 2000 | 07:45 PM
Car: Damn
Engine: This
OK i think i know what you're talking about now.
if you mean the numerous gaskets from the throttle body to the runners, then they go on dry.
sealant is not required on these because the tpi is a dry intake system, just air travels through it.
I hope this is what you asked about, otherwise i still don't know what you're asking.
88 CAMARO RS
Old Dec 1, 2000 | 09:11 AM
sguy30's Avatar
Yes, that is what I was referring to thanks. I also am debating whether to use thread sealant where the fuel lines mate with the injector fuel rail fittings. Should I? Then there is the question of whether to replace the orings on the end of the injectors (into the manifold). I have the gaskets, took one off to check the fit of the new oring and am noticing that the stack up height is much less than the original. The plastic seat has much more play in it than the originals. I doubt when the oring is compressed that it is going to make that much of a difference in stack height. So based on this fact and that the originals look fine I put everything back, only changing the one oring as I ruined the original. I reinstalled the injector and rail assembly and it seems ok. Think this is going to leak eventually? I figure there are no moving parts so I will be ok. I havent put on the air tubes yet so I can change all the oring if need be.
Old Dec 1, 2000 | 05:53 PM
Car: Damn
Engine: This
I've never used thread sealant on the fuel lines and never had a leak. some of the connections have o-rings in the femail side anyway.
As for the injector o-rings, if the new ones are really smaller maybe they arent the right ones.
My fel-pro intake gasket set came with 8 o-rings for the injector-manifold seal, not the injector-fuel rail seal.
i think that the o-rings are different sizes on the top of the injector and the bottom.
call a gm dealer and ask if they have 2 listings for o-rings.
hope i helped.
88 CAMARO RS
Old Dec 1, 2000 | 08:44 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Right, no sealant or teflon tape on the fuel lines, FPR, or for that matter any fitting that is flared or that has an integral "O" ring.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
hdis2002
Sep 8, 2015 02:52 PM
