383 Crank Clearance Template?
Old Oct 10, 2003 | 09:15 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I read somewhere of a bolt-on template you could buy to allow the DIY the opportunity to grind crankshaft clearance accurately for a 350 block used for a 383 buildup. Does anyone have a lead on this product?
Old Oct 10, 2003 | 12:49 PM
ede's Avatar
ede
guess you could use a template but it'd either have you grind more to allow for all the differant rod combinations or not grind enough. i think i'd just fit the crank and rods and use a gage to check clearance with
Old Oct 10, 2003 | 12:55 PM
wesilva's Avatar
Transmission: 200R4
Good Point. Thanks, ede
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
MM2Robinson
Oct 1, 2017 09:16 AM
