Fire in the Bores!
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Fire in the Bores!
Actually it was in the butterfly valves. Ok, I have my car stored, and I went out to just start it up and keep the gas fresh in there like I usually do. Its TBI injection by the way. Anyways, I took the open element off and was reving then engine with the throttle cable to get the engine hot. All of a sudden, BOOM, flames appeard and then died out immedietly down the butterfly valves and a quick puff of smoke. Car didn't stall out of nothin, it just kept on running like nothin happened. So what was that all about? Check my sig and see if it has to do with any of my mods. Thanks.
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Eric Natzke
Car: 4
Engine: 6
Transmission: 5
Lean condition, maybe a little condensation in the fuel.
If nothing was damaged (sounds like nothing was) then it's nothing to worry about.
pretty exciting when that happens. the best thing to do is open the plates and let it suck the fire back in the engine instead of catching something on fire out side the engine.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
Engine: 3.8
Axle/Gears: Dana 60
Oh yeah, it caught me off guard all right. I was reving the engine for my bro to see if we could make the work bench shake, which we did
and I had my face down by the TB and then FLAMES ON! Hahaha. But it went right out, no fire on the outside of the bores, just down in the TBI Spacer. It was just a quick flash.
Eric Natzke
and I had my face down by the TB and then FLAMES ON! Hahaha. But it went right out, no fire on the outside of the bores, just down in the TBI Spacer. It was just a quick flash.------------------
Eric Natzke
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Pretty common for when the air-cleaner is opened like that. I haven't seen it as much on TBI, but pretty often with carbs. I'm always pretty careful about standing back when ravving the engine from under the hood, I like my beard and hair the way they are!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
Was driving My friend vette around W/o the Hood One Night, and that Happend, Wow what a Show
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
**Mods**
MSD Superconductors
14" Open Element
KYB all around
