Question ive been meaning to ask...
Old Nov 30, 2000 | 05:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I have been meaning to ask this question for a long time, but i always forget. Ever since i put my Pro-flo air cleaner on, every time the secondaries open up it makes this loud sound from the carb that kinda sounds liek a rice burners exhaust. its hard to describe, but it souds like my carb had one too many bean burritos. Is this just the air being sucked in so fast or something? It never made this sound with the stock air cleaner.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
Old Nov 30, 2000 | 06:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The intake has pulses of air, just like the exhaust does. Each cylinder creates a pulse as it sucks in its air. So the air flow through there isn't a smooth laminar flow like water in a garden hose. The stock air cleaner serves as the muffler for this sound.
If that's the triangular air filter with the foam top, your car will probably have at least 15% more HP without it. It's a major restriction and gets dirty REAL FAST: look at how little filter surface area it has. It's a street-rodder look-cool part, not a go-fast one. Get a L69 dual-snorkel air cleaner instead. That's the best setup I know of for one of these cars. Above all don't get one of those "drop-base" units; they all locate the lid so close to the carb air horn that they're more restrictive than the L69 setup.
[This message has been edited by RB83L69 (edited November 30, 2000).]
Old Nov 30, 2000 | 06:14 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Really? I figured it was better because it is more free flowing than the stock one. What do you mean by drop-base??
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
Old Nov 30, 2000 | 06:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try putting your stock one back on and see which one actually flows better. You might be surprised.
Old Dec 1, 2000 | 09:31 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Thats the sound of a good old 4-barrel my friend! The best sound a car can make in my opinion.
Old Dec 1, 2000 | 09:49 AM
Guest
Guest
Posts: n/a
A pro flo? Those have a nasty habit of dropping their foam element right down the intake....
Old Dec 1, 2000 | 03:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ward, you can read this too, if you're bored. I had a more-detailed page somewhere, but of course, lost the link.
http://home.earthlink.net/~kiszka/du...procedure.html
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 1, 2000 | 06:01 PM
84TransAm's Avatar
No, way, not right down the INTAKE!! I thought they had pretty good lower support to prevent that, though it is plastic. Sure hope it isn't common
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
Old Dec 2, 2000 | 12:50 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
When I changed from the stock cleaner housing to the open air 14" element, I heard that sound and fell in love. I think that every 4bbl carb'd engine should sound like that!!! Even fords!!! I have the stock exhaust, and even though it rumbles, the rrrrrrrrrooooooooooooaaaaaaaaaaaarrrrrrrr of the engine is sooooo loud!!!!
YEAH BABY!!!!
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 2, 2000 | 04:14 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Actually, 84 it has a metal framework that keeps the foam from coming loose. I am not wild about it, but it was $5 from the junk yard and it takes up alot less space than the bigass stock one. I can actually see my throttle cable now! lol...
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
