87 LB9 Auto with a funny idle and stalling problems.
Old Nov 29, 2000 | 09:38 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I just got my new car (87 LB9 IROC) and after 400 mile drive home on the freeway I've noticed that the idle can change when your around town. It can be anywhere from 600rpm to 1100rpm?!? Sometimes it even stalls on me if I'm sitting at the lights or reversing.
Anyone got any ideas? It's TPI if thats any help.
Also, I had it running low on gas and was thinking that it might have sucked dirt in, what do you think and any ideas how I can fix it as it's REALLY annoying me. Engine temp also hangs about 190 in town.
Thanks for the help guys.
RMK
Old Nov 30, 2000 | 09:56 PM
1iroc2slow4me's Avatar
HEY MAN, i totally get what u mean, i ahve an 86 Lb9 auto car, does the same exact thing. i find myself revvin it up at lights in park to keep it "lit." thebest thing that u can do is see if its holding any codes, or if yer wealthy, take it to somewhere that has computer diagnostic parts, in my case i took it to school and used the tech teachers computer. bc if its holdlin codes, it might be just a simple sensor, or relay, or bad ground somewhere.
feel free to email me at z305@hotmail.com
eric
Old Nov 30, 2000 | 09:58 PM
i meatn revvin it up in drive
eric
Old Nov 30, 2000 | 11:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Eric
Have you tried fuel injector cleaner? I was thinking about trying that to see if it makes a difference. I don't se it doing any harm anyway. Also, has your car always done it?
RMK
1987 IROC-Z Auto (LB9)
Black/grey with kick *** looks
Mods
None yet as I just got it Tell me what to do to it and I'll do it though.
Old Dec 1, 2000 | 12:22 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I was thinking about trying injector cleaner, have you tried that yet?
RMK
Mods
Old Dec 2, 2000 | 09:38 AM
Vader's Avatar
RMK,
1. Injector cleaner probably won't hurt, as long as it isn't methanol-based.
2. Injector cleaner probably won't help if the injectors are already varnished to the point where you are noticing a difference in idle quality.
3. Unless you are getting a rough idle, the injectors are probably not the cause of you "wandering" idle.
Idle speed is controlled by the IAC stepper motor and is dependent upon several inputs to the ECM. Coolant temperature and TPS voltage are important. The PCV system and all vacuum lines need to be intact. The EGR valve should be sealing when closed instead of leaking through. The IAC stepper and its air passages need to be clean. A clean throttle body certainly can't hurt.
If you check the Tech Articles section on this site, you should find some hints.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
gta90
Sep 15, 2015 04:00 PM
Bryan F
Aug 18, 2015 02:28 PM
