Advice needed on heater core replacement
Old Dec 1, 2000 | 05:36 PM
it3's Avatar
it3
Hey Guys/Gals,
For the last few weeks, I have had wet floors in my 1992 Camaro RS 25TH Heritage Edition (Passenger and driver side). The liquid isn't green, doesn't smell(like antifreeze anyways), and isn't greasy feeling. I called a local garage, and they said they thought it could be the heater core's valve draining?? I'm a novice at car repair, so I have no idea what to think?
I do have a guy that said he would beat the garage's price, and he is ASE certified, so I think Ill let him do it.
What are the bare essentials that I have to remove to get to the heater core?
And any other important things I may need to know before starting this would also be of great help!
I hope to see lots of responses please!
IT3
Old Dec 1, 2000 | 08:32 PM
Marc 85Z28's Avatar
If it doesn't look like antifreeze, it doesn't smell like anitfreeze, and doesn't fell like antifreeze, it's probably not antifreeze!
There is no valve on your heater core: the guy you talked to is an idiot.
And if it was your heater core, you would have fluid on your passenger side only, not the driver's side too. Get that bad heater core idea out of your head, it's not your problem.
It would really help if you posted your location when you registered...I would know your climate/weather. Anyway, has it been raining or snowing lately? If so, check your weatherstripping along your doors and t-tops if you have them.
The only other thing I can think of is that your cowl vent is leaking morning dew/condenstion into your interior through your ventilation. I'm not exactly sure how the cowl vent is supposed to prevent this, so maybe someone else can help you with that.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Dec 1, 2000 | 09:10 PM
it3's Avatar
it3
I live in Southern Ohio.
It stays wet even when it hasn't rained outside. I was thinking that the cowl vent might have been a potential problem. I dont have t-tops (nor want them)
Hope I covered everything
Later
Old Dec 2, 2000 | 07:20 PM
Pat Hall's Avatar
Later
One obscure place I've heard of these cars letting water in is where the engine harness passes through the passenger side fender to go to the ecm. There's tar around the wiring harness where it passes through a hole in the inner fender. Sometimes this can leak if it has been disturbed somehow. However, you would only have water on the passenger side front floorboard if this is your problem. I'd definitely rule out a heater core problem, unless you're running straight water in your engine! As far as any drain valve, the only thing that would make sense there is if they're suggesting that the drain for your A/C evaporator core is plugged and overflowing into the car when you run the A/C.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
NBrehm
Aug 5, 2015 07:57 PM
