L98 FUEL PUMP... is it goin south?
Old Dec 3, 2000 | 08:54 PM
nicksL98's Avatar
Ok. here is the situation i have yet to chek the FP setting on the car BUT.. recently the pump has started to run-on after you shut off the engine for like 5 seconds or a little more. The noise was a slow whine then it went to a deep droan/groan. When the car operates normally during driving...the pump seems awfully loud (to me anyhow). ANyone have any ideas?
Also .. what pump should be purchased (mfg., FP/LPH rating, etc.)
Thank you!!!
Old Dec 3, 2000 | 09:10 PM
Mark 89Formula's Avatar
My original pump started groaning when it was on it's way out. The right way to check is by monitoring fuel pressure under load. You can also monitor oxygen sensor output under load to see if it drops.
If you need to change the pump, get a Walbro 255 LPH unit. It can handle just about anything you can throw at it. You can pick them up for just over $100 on the internet.
89 Formula 350, Accel Tri-Ys, 3" SLP, chip, Jacobs, SLP cold air, Probuilt tranny, Vigilante, 3.27s, Spohn torque arm & LCAs w/brackets, GW Subs
Old Dec 3, 2000 | 09:30 PM
theformula's Avatar
NicksL98, you better pray to God it isn't your fuel pump. Thats a job you don't want to do.
Anyway, it's normal for the fuel pump to stay on a few seconds in colder weather.
Check your FP. Check for consistancy also.
You won't need a Walbro pump unless you plan on doing some serious mods. You can get an Ac Delco for $69.99 at any Autozone
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
[This message has been edited by theformula (edited December 03, 2000).]
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
TheExaminer
Aug 19, 2015 10:07 PM
