White spark plugs = Running lean?
Old Oct 14, 2003 | 01:04 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
A few weeks ago, while driving around 50, it sounding like a cardboard box was stuck under my car and after that noise went away, a rattling started in the area of the converters. I’m in the process of adding super high flow cats (so high flow you’d swear that they had a straight pipe through them) but I also started a tune up also. I pulled my plugs and they were all white. I also checked the timing and it was only 4 degrees advanced. I put it back to 6 degrees and it idles smother but still sounds like an exhaust leak (I’m almost certain that it isn’t) and has no power. I don’t have any overheating problems either. Could a clogged converter cause a lean condition?
Old Oct 14, 2003 | 04:52 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Yes a clogged covertor can cause excessive exhaust gas temps. Not sure I would call that a lean condition but it would have the same effect. I worked on a Triumph Spitfire with a clogged cat, the piping before the cat was glowing red hot!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
