c4 quadrajet air bleed
Old Dec 3, 2000 | 02:56 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
just in front of the air horn there is a plate that can be removed that exposes an adjustment screw which I understand is an air bleed adjustment... My question is what should you moniter while adjusting this... duty cycle of the mixture control selinoid??? O2 voltage??? or what else??? any help on this and the correct procedure of what must be done before doing this is greatly appriciated...
P.S. anyone know what the correct metering rods and jets on a L69 (305 HO) are???
thanks
zroc
Old Dec 3, 2000 | 09:44 AM
Vader's Avatar
Zroc,
Check this file:
E4ME.pdf
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 4, 2000 | 01:56 AM
zroc's Avatar
Car: 87 IROC
Thanx Vader... whish I had access to that info (hint hint)...
Old Dec 4, 2000 | 11:50 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Look in the "Renegade of Funk"'s (Vader) sig to download the needed program.
The consensus for the OEM secondary rods and hanger for the L69 are "DR" rods and "F" hanger. The primaries are the same and (IIRC) not interchangeable.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
dimented24x7
Sep 6, 2015 03:51 PM
scotrans am
Sep 5, 2015 04:26 AM
