28spline axles,drivers side/passenger side interchangeale?
Old Dec 4, 2000 | 11:39 AM
theformula's Avatar
I have a rear at home with only one axle.
Its a 3:42 with posi and one 28spline axle. The other one cracked in half.
And.....I have the driverside 28spline axle. Would I need to buy the passenger side replacement. Or could I find another 28spline drivers side. In other words are they interchangeable or designated for a certain side?
and.....I was wondering ....could I use just the housing from an old 26spline rear I have sitting at home for this project?
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 4, 2000 | 12:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 2 axles are the same. So you don't have to specify which side when looking for a replacement. They are the same length, etc.
The housings are the same, as far as the axles are concerned. You would have to use a 28-spline carrier in either housing to use the 28-spline axles.
You may run into other disc/drum compatibility issues with a 26-spline housing if it's a drum one... look them over carefully before spending money. I personally wouldn't put either drum brakes, or the early-style discs (like the 9-bolts and the old 10-bolts have), into a car if I could help it.
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Bert87
Aug 23, 2015 03:50 PM
86IROC112
Aug 20, 2015 12:18 PM
Cameeeero
Aug 20, 2015 03:06 AM
blacksunshine'91
Aug 10, 2015 12:04 AM
