TEmp sensor on Thermostat Houseing
There is a Temp Sensor (I belive its a temp sensor, anyhow ) On the thermostat houseing Of the LG4, What uses this ? And what Problems am I going to Run if I Remove it?
Also, Is there any reason I couldnt Just relocate it to another Coolant passage That wasnt Right On the front Of the Motor ? This is an Effort to Clean Up The Engine Bay.
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Car: 4
Engine: 6
Transmission: 5
If it's the one with 2 wires (yellow and black) it belongs to the ECM.
There are as many as 3 temp sensors: the one oin the left head goes to the gauge; the one in the water outlet is for the ECM; and the one in the right head (if you have that) works the electric fan.
Transmission: 4L80E/4L80E
The thermostat housing is the only location down-stream of the thermostat, which is what they wanted for that sensor.
Ahh ****, I guess Ill just Sandblast and Paint the Houseing Instead o getting a Nice MR gasket one
**Mods**
MSD Superconductors
14" Open Element
KYB all around
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Car: 4
Engine: 6
Transmission: 5
Don't waste your money on that chinesium POS the factory used. This would be a classic case of trying to make chicken salad out of chicken s***.
Get a new cast iron one (less than $10) and expend your effort on that, you'll have a whole lot less trouble in the long run, and probably spend less money besides.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The sensor on the thermo housing is the ECM temp sensor. If you remove it, the computer will throw a code. BTW, there is another temp sensor on the drivers side of the block which goes to the gauge. Moving the sensor to another coolant passage shouldnt hurt, as long as its not too far from the thermostat housing so the water temp isnt very much different.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
dbrochard
Oct 3, 2015 12:43 PM
