bad oil pressure guage in a 91 firebird?
Old Dec 5, 2000 | 02:50 AM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
My oil pressure guage seems to be retarded. When I press the gas, it jumps up really high.. if not, it's around half.. what's probably wrong with it? Thanks.
Kevin
Old Dec 5, 2000 | 05:59 AM
CamaroMike's Avatar
At least yours moves! Mine just stays at 10 then 20 then 30 and back to 20 every 10 days. Junk gauges.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
[This message has been edited by CamaroMike (edited December 05, 2000).]
Old Dec 5, 2000 | 07:35 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Which engine?? Is it a fluid movement or is it really jumpy??
If you are worried about it try replacing the sending unit for the gauge.
I've rarely seen a gauge fail. These aren't the most accurate gauges in the world...but thats a different complaint
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 5, 2000 | 09:23 AM
Enkil's Avatar
That sounds fairly normal. The pump puts out more pressure the heavier the load on the engine is. So, when you floor it, the pressure guage should go up pretty significantly. Sometimes my guage goes over 60, but I've got a higher than usual pressured oil pump in there anyways. The 85 z28 I had and the 89 iroc's pressure gauges both did the same thing.
Old Dec 5, 2000 | 02:11 PM
Car: 91 Firebird
Transmission: A4
305 engine TBI. It's a nice smooth motion, but it's usually really quick. Usually while I'm driving, it's off the charts, which is why I think it might not be working right (or some other part connected with it).
Kevin
[This message has been edited by 91FireChicken (edited December 05, 2000).]
Old Dec 5, 2000 | 06:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its not the gauge, its the oil pressure sender. Thats the canister thing just above the oil filter. Replace it and your gauge will work correctly again.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 5, 2000 | 07:04 PM
Macgyver's Avatar
Mine does the EXACT same thing, I know it's the sending unit, but get this, my car started doing it immediately after a buddy accidentally put 5 qt's oil in the motor, odd...
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
