Budget 400SBC Buildup...
Old Dec 5, 2000 | 05:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
This summer, I will be building up my engine, but I am on a budget. Right now I make about $400 a month (part time, hey im 17). This summer I will work full time, so i will have more money. I will most likely remove my ECM because I can pas emissions without it. All I need for emissions is the stock air cleaner, heat riser pipe, and pass the sniffer test. Dotn worry about the air cleaner, though, it takes like 5 minutes to put on for inspection. Anyways, I need to know what is the best intake, carb, ignition sys, cam, heads, and other stuff to use. Heres my plan so far, but please tell me if there is something I can improve;
Intake: Weiand Stealth, Action+, or Edelbrock performer (which is best?)
Heads: Iron heads with mild porting & 2.02/1.6 valves
Cam: Summit cam kit K-1104 - .265/.265 228*/228* dur. with 112* separation. I want a lopey so can I go bigger & still have good vacuum?
Ignition: ???Vacuum HEI???
Carb: ???Vacuum Q-Jet???
Exhaust: Summit headers, no cats, dual flows exiting i nfront of the axle
I am shooting for about 300 Hp for now, because I dont want to break the tranny or rear.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Dec 5, 2000 | 07:46 PM
ede's Avatar
ede
you got mail
-=ICON MOTORSPORTS=-
1st & 3rd
cheesehomer
Dec 31, 2015 08:48 AM
Jorlain
Oct 8, 2015 01:57 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
