TPIS Big Mouth Install
Old Dec 4, 2000 | 06:33 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I just installed a TPIS Big Mouth Intake Manifold on my GTA. Before I put the runners, fuel rail, plenum, and throtle body back on I filled the radiator with coolant. Coolant started to leak from a tapped hole by the distributor hold down bolt. I plugged it with a bolt and some teflon tape. This bolt came with the Big Mouth. I also plugged an identical hole on the alternate side towards the front of the Big Mouth with another bolt that was also supplied with the package just to make sure. Then I began to fill the radiator up again, and there was another leak. This time it was coming out of the the hole for the runner bolt on the driver's side. This is the bottom bolt hole between the rear two runner inlets on the driver's side of the manifold. I haven't started to fill it up again. I want to install the runners, with teflon tape on the bolts first to make sure that leaks don't come from thr other holes. Has anyone ever had this problem when they installed this manifold on there cars?? Am I the only person who had this problem?? The car is almost finished. I have already installed a TPIS ZZ-9 Camshaft, matching valve springs, and a Cloyes True Double Roller Timing Chain. I don't want to have to return this manifold to TPIS and have to wait on them for delivering a new one since the car is almost ready to be fired up. Anyone with comments of similar criteria will help to ease my mind on the subject. I will definitely notify TPIS on this.
Old Dec 5, 2000 | 09:11 PM
Vader's Avatar
Joe,
I have no experience installing a TPIS intake, but I would recommend something other than PTFE tape for sealign engine fasteners. Pipe threads are O.K. for this product, but straight threads should be sealed with Loctite PST sealant or an equivalent product to assure a permanent seal.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
