It's alive! 355 Vortec+Hot cam
Old Oct 17, 2003 | 08:23 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just finished getting my melonized gear from GM to finish My swap from XE268 cam to LT4 hot cam. It fired right up and after some valve lash adjustments I took it for a short ride. The idle sounds awsome, sort of chppy like the 268 only better. The torque increase was amazing and it just runs like the beast I knew it always was. Maybe I will get into the 13's now.(13's here are 12's at sea level). I'll post times for sure the next time I go to the track. I heard that this cam comes to life above 4000 and I've only taken it to 3000 and I still like it better than ole 268. Rollers rule
Old Oct 17, 2003 | 09:18 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Glad you like the new found power! I thought the Hot Cam was more of a tq. cam?
Old Oct 17, 2003 | 10:55 PM
GASGZLR's Avatar
I'm not sure what kind of cam it is but it's sure a great cam. The torque band is matched perfectly to my converter and it pulls hard up to.... well, I only took it to 5600 and it was still pulling.
The HOT cams .492 lift(w/1.5 aluminum roller rockers) is perfect for my vortecs since they flow best around .500. I was thinking about going to 1.6's but it runs awsome now and .525 lift is more lift than I would want to put on my Comp 981 springs, even though they out perform GM's LT4's. I don't want to spend another 180 bucks on rockers when I already have a good set.
Comp 981 GM LT4/ ZZ4
Installed 110#@1.70 101#@1.78
Open 295#@1.250 250#@1.33
Rate 417 lbs/in 332lbs/in
Coil Bind 1.150 1.22
GM recommends not going over .525 lift with their springs and Comp recommends not going over .490<-?(don't ask me why) but I think .492 or .525 is OK
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Billy Decker
Sep 4, 2015 03:46 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
