What should my timing be after a 350 swap?
Old Dec 6, 2000 | 05:51 AM
gsmann's Avatar
Over the summer, I dropped a 350 with big lobe cam in my 86 TA.
it's TPI and has the following things done to it:
custom LEVEL IV TPIS PROM
110 LS CAM
AFPR set at 48 psi
ACCEL SUPER COIL
MSD 8.8MM wires
BOSCH Platinum plugs
RAM AIR
TRUE DUAL EXHAUST
What should I set the timing to?? right now, it's at 6 BTDC. It runs fine but Would it run better at a different setting?
Old Dec 6, 2000 | 07:47 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I would bump it up to 10 and see how it runs.....
Might want to give the chip mgf. a call and see what they suggest.
I run my 400 at 12.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
