worn cam, performance loss?
Old Oct 18, 2003 | 06:43 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I was thinking today, and just out of curiosity was wondering. how worn would a stock roller cam be after 193,000 miles? also how much performance loss would there be due to it.
Im realy kind of curious if maybe a new cam souch as the Vortec cam from competition products would put a little life back into my engine.
my engine runs rather smooth, but some thing can not be right with it. wile its not the best way to get times I had a friend clock my 0-60 time today with a stop watch and it was around 11 seconds.
Old Oct 18, 2003 | 06:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Consider this... 95% of the wear that a cam will go through in its lifetime occurs during the first 30 minutes of break in.
Old Oct 18, 2003 | 07:05 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
193,000 miles should warrant rebuilding the heads. That should give you some power back.
Old Oct 18, 2003 | 07:13 PM
Car: 91 Camaro RS
Engine: 305 LO3
how hard would it be to clean up and rebuild the heads my self?
Old Oct 18, 2003 | 09:21 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Unless you have a machine shop eqquipt with valve grinding eqquiptment leave it to a pro. It usually runs around $150-200 to have heads fully gone through including a 3a valve job.
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
ambainb
Aug 29, 2015 12:43 AM
Bradsaundry
Aug 12, 2015 12:34 AM
