i got my car out finally with all mods and the thing is way different shifting, HELP
Old Dec 4, 2000 | 10:17 PM
saul 87vette's Avatar
it wont manually go into 1st gear. the tv adjustment wont help this either i tried. also it shifts at the wrong times way to early. i need help bad what all can i adjust here
Old Dec 4, 2000 | 10:25 PM
ede's Avatar
ede
check your shifter cable to the trans and make sure it's adjusted right. recheck the tv cable. other than that i'm out of ideas.
saw jimmy and steve few weeks ago at wal mart here. were you down? you should try to hook up with me when you're here sometime.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 4, 2000 | 10:35 PM
i was down actually. i will have to get a hold of you when im down next time. ill check the other cable also
Old Dec 4, 2000 | 10:48 PM
Guest
Guest
Posts: n/a
I dont know what all you've done, but when the throttle is all the way open, the tv cable should be fairly tight. If its loose, its probably disconnected inside the trans (or maybe its broken).
Old Dec 5, 2000 | 02:00 AM
Pat Hall's Avatar
I have to agree with Madmax, it sounds like your TV cable is either broken or too loose. My trans acted almost exactly like that when the end of my TV cable snapped off the throttle linkage.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 5, 2000 | 10:48 AM
ill check on that. it could be broke inside tranny?
Old Dec 5, 2000 | 01:39 PM
cfabe's Avatar
Sure, it could be broken or disconnected inside the tranny. When I bought my t/a with the 82, the thing wouldn't downshift. turns out the little wire that hooks onto the tranny end of the TV cable had broken off. There was enough slack to bend a new hook on the wire. Not an easy job because of the limited space to work in, but probably easier then puling off the pan to replace the little wire.
82 T/A 305/TH350; soon to be 350/T-5
Old Dec 5, 2000 | 03:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A busted TV cable won't let you manually grab first? I didn't think the TV would affect that...?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 5, 2000 | 04:42 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
yeah, its definatly NOT a TV cable.. the tv cable wont affect manual shifting.. first what all mods have you done?
Old Dec 5, 2000 | 08:37 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
Hey guys this post caught my attention because I am having a very similar prob. I cannot get a 1st gear by shifting manually, works fine during auto shifts and true adjusting TV cable does not effect this but I know the TV cable is working cause I can feel it shift differently when I change adjustment so I am also interested in hearing any possible causes or fixes
THANX
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
Old Dec 6, 2000 | 01:00 PM
well, i got the tv cable adjusted perfectly but still wont go into 1 manually because this is on a different adjustment cable and i know nothing of how to adjust it. but i am down for a while now anyway. the damn tf g2 heads i put on the car got recalled! i knew something was bad wrong with these heads when the one would not hold proper torque on the rocker studs and i had to send it back. well they sent a new one and it turns out the other one i didnt send back which torqued down fine is now ****ed due to a rocker stud pulling out! this is not even the problem these heads had to warrant a recall? it was sopposed to be a bad cut on the valvejob. i had not even revved the car past 4000 yet either due to break in and all. too bad.
Old Dec 6, 2000 | 03:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If I could guess at the problem grabbing 1st, I'd say something's hanging up the shifter cable.
You can go under the car and unhook the shift cable from the shift lever (on the trans). If you then rotate the shift lever "back" all the way (car off, parking brake on, block wheels), and then put the shifter in first, you could check to see if the cable meets the shift lever exactly.
Ultimately the tranny's shift lever will tell you where first is. If the shift cable from the shifter can't match the tranny shift lever hole, then something's wrong with the cable/shifter... at least that's my guess!
Old Dec 6, 2000 | 05:09 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
ill second checking the shifter cable, and assembly.. including getting under the car and having someone work the shifter from inside, making sure it clicks into and out of every position.. chances are good the cable just isnt moving the selector on the side of the tranny far enough to engage first.. or even before doing this to try saving some time, try pulling it back into first using a little bit of force (not too much), that may be enough to get it to engage.. mine grand am does the same thing, just too lazy to adjust the linkage..
Wade787b
Sep 29, 2015 01:15 PM
matthew911
Aug 12, 2015 09:38 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
