Drivers side running rich
Old Dec 4, 2000 | 11:07 PM
chriskemper's Avatar
I pulled the plugs on the engine to see what could be causing stumbling at idle. All the plugs on the drivers side of the engine were coated with carbon, the passenger side looked perfect though. Any thoughts as to what could be causing it. Car in question is 89 IROC with 305 tpi.
Old Dec 5, 2000 | 08:15 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I'd like to know too I have the same problem with my car but mine is leaner on the driver's side ???
1987 IROC w/T56 and a 383 TPI in the works
Old Dec 5, 2000 | 08:59 PM
Vader's Avatar
Chris,
Welcome aboard!
The lean/rich condition is probably less related to fuel delivery and more likely due to a leak in an intake gasket, mismatched components, or an ECM problem.
What kind of fuel system/year/engine do you have?
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 6, 2000 | 06:35 PM
Its an 89 with 305 tpi. Basically stock engine. I have noticed that the first injector on the drivers side looks physically different that the other three but could that cause the entire side to run rich? If the gasket is leaking would it be on the passenger side (a leaking side would be lean right?)
Chris
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
