Will L98 heads work on an LG4?
Old Dec 6, 2000 | 07:58 PM
Dan87IROC-Z's Avatar
I know the L98 heads aren't the 2.02"/1.60" valves, so they should work, right?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 6, 2000 | 08:28 PM
Cosmik Debris's Avatar
They will bolt on but with 64cc chambers you will lose a lot of compression. The alloy L98 heads off of a vette are 58cc the same as 305 heads and are a better choice.
Old Dec 6, 2000 | 10:39 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've got the aluminum L98's on my LO3, I've got some pictures and flow tables on my website...if ya' wanna check 'em out.
-Mark W.
'88 SC Camaro w/ 305 TBI
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
