tire pressure...what do you run?
Old Oct 20, 2003 | 05:31 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
Im just wondering what people are running in there
245/50/16's
I always had run like 38-40.... but Id like to see what everyone else is running
Old Oct 20, 2003 | 06:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hmm you should probably go by what the tires are rated for.. it should say on em.. i normally keep mine around 32-33ish
Old Oct 20, 2003 | 06:44 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
44 is max
Old Oct 20, 2003 | 09:41 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I work at a pontiac dealership, and I generall fill everything that comes in my bay to roughly 32 psi. for the 245's, I generally wouldn't go much higher than 35. Remember, when it comes to tires, you generally want to stick right to what the TIRE calls for. Going higher will take less tread off the road, while too low allows it to ride on the sides of the tires and actually buckles the middle of the tire in. So I would go with what's on the tire, if there's nothing on there, go with 35.
Old Oct 20, 2003 | 10:05 PM
llvll4l2c91350's Avatar
Old Oct 21, 2003 | 04:35 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
usually 32-34psi front
little softer on the back cause i have no tread
30-32psi
all 245/50 R16s
I have no alignment, wander issues (cept for some of the roads I have to drive on under breaking)
and no uneven tire wear.
Old Oct 21, 2003 | 05:42 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
ok thanks guys..I guess I'll go around the 35 mark
seeings that the max is 44 PSI
Old Oct 21, 2003 | 07:59 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
That is wrong. If the vehicle has OE size tires with an OE load rating you should go by the Tire Sticker. In my IROC the sticker reads 30 Front and 30Rear cold with the OE 245/50/16 tires. GM also recommends adding 4 psi to that if the tires are hot. Now this is for "normal" driving. If you autocross or drag race or just prefer a stiffer or softer ride you adjust to your preference. The pressure rating on the tire is the max that tire is designed to handle, not what it is supposed to be inflated too.
Old Oct 21, 2003 | 07:44 PM
Stingraye's Avatar
Car: 1986 Trans Am
OK, so then you are agreeing with me, i'm not wrong. What I said is you want to stick right to what the TIRE calls for, if it's still OE than you can find out what it calls for either on the tire itself or inside the drivers door. What you said there agrees with how I put it. Just makin sure we're on the same level here...
Old Oct 22, 2003 | 07:49 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I do believe I read that too fast and too early in the morning. I misunderstood what you had said. I now know you meant go by the tire if the manufacturer spec is unknown, but not to exceed the tires max rated psi. I guess I have gotten a little tempermental after seeing several cars in my bay with tire pressures in excess of 80 psi when spec is 26 psi.
You have my sincere apologies. 7:00 am on Monday sucks
Old Oct 22, 2003 | 08:04 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
32 all around. Whats a good psi to run on a Friday night?
Old Oct 22, 2003 | 08:17 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
I think 40 ....oops wait thats 40 oz
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
