Is it normal for the air filter to reak of gas?
Old Oct 21, 2003 | 12:31 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I took off the air cleaner lid the other day to see if it was dirty, and the thing smelled like gas. I took it off the next day same thing. I'm not sure what its called but the little foamlike filter thing in in the air cleaner seems like it is filled with oil. Is this normal?
Old Oct 21, 2003 | 01:55 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
THe only time that I could smell gas coming from the air cleaner was when my carb used to get real hot and boil off the gas inside it. Are you a TBI car or carb?
Old Oct 21, 2003 | 01:58 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
91 305 TBI
Old Oct 21, 2003 | 05:44 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
the oil on the pad is normal, it is a filter for the pcv valve. if its bad it should be replaced
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
