Largest cam for 9:1 350?
Old Oct 21, 2003 | 05:54 PM
84zeddd's Avatar
What is the largest cam you can run on a 9:1 350 without giving
up all your bottom end torque?Can I run the Comp Cams XE274
(.487 lift 230@50 int,.490 lift 236@50 exh).Anyone running 12`s
with the Comp Cams XE268?
Old Oct 22, 2003 | 12:29 AM
KYL98's Avatar
Car: 1991 Z28
I would call CompCams and get some expert advice from them.....Tell them exactly what you motor has, and what you want it to do...and they'll hook you up....good luck
Old Oct 23, 2003 | 10:31 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
The 268 has good low end torque and is a good street cam that will still rev to 6000. I can run 13.5 without the best traction with the 268. I have 10.3 to 1 comp though.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
