VSS, hard to replace?
Old Dec 6, 2000 | 01:51 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Just wanted to know. My spedo has not worked for like 4 months and now my service engine soon light is coming on. I get a code 24, which says it has a problem in the VSS. I priced one out for $57 at auto zone. What do I do, just pull the wires out of the old one, plug the new one in (on the back of my tranny) and I am ready to go?
25th Anniversary Z28
Check out my car at:
www.mylecdekmat.com/mgofast.htm
Old Dec 6, 2000 | 03:00 PM
Blade's Avatar
It's most then likely that the gear has slipped off the output shaft and it's not spinning to the VSS sensor. It happened to mine several times until the tranny shop did something to fix it.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Dec 7, 2000 | 07:46 AM
Pat Hall's Avatar
If you remove your VSS and you can see the drive gear right there, more than likely, it hasn't slipped and your sensor is the culprit. If your speedo drive gear has slipped, you'll have to remove your tailshaft housing(pretty easy to do) and install a new clip in the speedo drive gear. Btw, a new clip is only like a couple of bucks from the dealer.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 8, 2000 | 04:20 AM
Pat Hall's Avatar
Hey Ryan, if you need any help fixing it, give me a call. Pat.
Old Dec 8, 2000 | 11:05 AM
GOFASTER's Avatar
Engine: 388 ci
Sounds good guys, thanks....
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
