What is this part?
Old Oct 23, 2003 | 12:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What is this part?
what is this part? like a little 1/2 cylinder located just above/behind the brake booster? and what does it do? im restoring the engine and dont know how to hook this part up. thanks.
Old Oct 23, 2003 | 12:19 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I think it is the air reserve for the HVac controls.
Old Oct 23, 2003 | 12:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
okie dokey. so its not 110% critical to start the car.
Old Oct 23, 2003 | 12:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need it.
It has one small port, that the thin plastic vacuum line that goes to the firewall hooks to; and one larger port, that hooks to vacuum on the engine, right behind the carb.
Old Oct 23, 2003 | 01:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
does it effect fuel delivery though? because that is where my main problem is.
Old Oct 23, 2003 | 01:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It would affect air delivery.... as in vacuum leak. Doesn't have anything to do with fuel itself though.
Old Oct 23, 2003 | 01:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
would that by cahnce have anything to do with how the carb plate stays open versus closed at idle? for a while, the carb plate stayed closed at idle so when i fired the car up it red lined
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
