TPI long block
Old Oct 23, 2003 | 11:32 PM
killerIROC's Avatar
TPI long block
If I buy a long block or short block, like a ZZ4, Fast Burn, or 350 H.O. and H.O. Deluxe, can I install the TPI setup as long as I have everything necessarry? (i.e computer, wiring harness, sensors, etc) And if I wanted to buy a long block or short block which ones would be compatiable with most of the parts and accessories off the L98? (i.e. water pump, damper, flexplate/flywheel, distributor, starter, etc)
Old Oct 24, 2003 | 01:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The HO and Fastburn have Vortec-style intake ports. Using them will require the SDPC Vortec TPI base. If you opt for HO, your best bet is to get their TPI version, which has the base and a cam that will bring the TPI power up to the carb'd HO standard. Also requires a supporting cast, including PROM tuning.
The ZZ4 would be the most compatible for the reason stated above. All of the things you mention at the end would fit any of those engines, though.
Infested
May 22, 2018 11:56 PM
MoJoe
Sep 15, 2015 12:50 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
