Suggestion on spark plug gap?
Old Oct 24, 2003 | 01:16 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i know the stock gap is supposed to be .035, but i wanted to know if i can go higher with the few ignition mods i've done. i put a new accel cap and rotor, accel 8 mm spark plugs, and a 53,000v hypertech coil... what would be a good gap to put my plugs at to get the most power out of my setup? my friend told me .050 would be fine, but i wanted to get more opinions.
i know i won't make a SOTP differnce in power with just a coil, cap and rotor, but if i set the gap to .045 or .050 (depending which one would be better), how much more hp do you think i'd manage? 3-5hp? it's not like it would matter, it's just good to know
Old Oct 24, 2003 | 01:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Uh, let's make that .035". Half an inch would be a bit much to expect a spark to jump, even with 53kV.
You could probably go .040 easily, and possibly .045. Any more than that and you'll risk blowing out the flame under high pressure conditions.
You'd probably gain as much by cutting back and rounding the corners of the ground electrode.
Old Oct 24, 2003 | 01:45 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
lmfao, oops, my bad... lemme go edit that
is this what you're talking about? i wasn't sure if that was a good idea to do, but if you guys say it would help, i'll do it... i have nothing better to do tomorrow lol
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
