Lot of Oil Blow By
Old Oct 26, 2003 | 03:27 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Lot of Oil Blow By
Hey Guys Im tottally stumped.
I havnt Driven my car in say a month And i noticed its was dripping a small amount of fluid so i jacked the car up looked under it and theres a lot of Blow by above my Oil filter. It seems to be coming from Around the exsaust manifold. Any Ideas suggestions Im really tight on cash so i cant rip apart my motor.
P.s its only coming from my driverside manifold and trailing back to the transmission
Old Oct 26, 2003 | 03:36 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I would first say inspect your oil sending unit right above the filter, they can be known to leak oil right in that general area, and also look around your distributor to see if oil is escaping around the distributor shaft, you may be in need of a new distributor O-ring. Hope that helps.
Old Oct 26, 2003 | 03:42 PM
Thanks Man For the lighting fast Response
Ill go out and check now Never thought about the Dist.
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
