running on seven cylinders
Old Dec 9, 2000 | 09:39 PM
dude12387's Avatar
my friend who is much better than i with cars is telling me that im running on only seven out of eight cylenders. How do i prove him wrong (hopefully)??????
Old Dec 9, 2000 | 10:49 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Huh? Is your friend being serious or just trying to insult your car? If he came to that conclusion, either he already knows what the problem is, or else he's talking out his ***. Meaning, if the car is really running on 7 cylinders, he would have had to look under the hood and investigate to know this. If you are only running on 7 cylinders, then the problem is most likely in the ignition. Check to make sure that the distributor cap, plug wires, and spark plugs are all in good condition. The ignition is usually the cause for having one cylinder out, unless you have intertnal engine damage, like a burned valve (which is probably not the problem). If you are running on 7, the car will idle rough, kinda shaky, and it will be a real dog, sluggish accelleration. If you have a burned or cracked plug wire that is grounding out, you can sometimes hear it really faintly. It makes a slight ticking noise. It's possible that your friend is hearing this.
Old Dec 10, 2000 | 09:12 AM
ede's Avatar
ede
easy way to tell (but puters compensate for this any more) is to pull a plug ire and see if the preformance changes. repete till you pull a wire that doesn't change the preformance. another method is to mark each exhaust port on the manifold with a crayon (cold engine) and start it up, they all should melt and run more or less at the same time. if you have a dead cylinder you won't have any heat and the mark won't melt.
ICON Motorsports
1st & 3rd
Old Dec 11, 2000 | 03:31 PM
crazeinc's Avatar
if it idles bad and if you floor it and it stumbles around you're probably missing a cylinder (I know, I forgot to plug a wire back in a few weeks ago )
Old Jul 25, 2006 | 12:44 AM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
When I was running on 7 cylinders (wire unplugged), I didn't really notice a huge difference. Yeah the car was somewhat slower, I noticed I couldn't spin the tires, but it didnt stumble around too much, and still had decent power. I did notice that the tach was bouncing around a little bit though.
Old Jul 25, 2006 | 09:22 AM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
i had this problem once but i was down two cylinders. i lost alot of power and my exhaust smelled like gas. it ended up my headers burnt though 2 wires and after i replaced them all it was gettin a new car again it was fun but yeah i agree with everyone just go through and check you ignition
Old Jul 25, 2006 | 01:46 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I had an old plug wire short out on the O2 sensor body, and yeah, it was real obvious when one cylinder cut out. The engine was vibrating a LOT more, you could hear it in the exhaust, and there was a noticible drop in power. If you're running on 7, it should be pretty obvious. A new set of Taylor spiro-pros solved my problem, and they even fit in the OEM looms, snugly.
Old Jul 25, 2006 | 10:59 PM
87z28fromhell's Avatar
Car: 87Z
Engine: top secret
Transmission: top secret
I have a collapsed lifter. It was banging pretty hard so I adjusted it down tell it stopped banging. yeah the performance is down a lot but it will last a little while until the 383 is built.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
