VERY Rich Fuel Mixture
Old Oct 26, 2003 | 10:25 PM
rs_boy's Avatar
Car: '89 IROC-Z Convertible & '91 RS
What's up guys...I have a 3.1L engine and my fuel mix is VERY rich. The other day I adjusted my idle since it was way too high. Ever since black smoke has been shootin' out the tail pipes on initial start-up and also when you give it alotta gas. What could be the problem and what should I check out? Thanks in advance guys.
Old Oct 27, 2003 | 06:13 AM
ede's Avatar
ede
well if your problem started after you "fixed" your car i'd un fix it and see if it goes away. you might want to scan for codes and make sure the tune up is good
Old Oct 27, 2003 | 10:37 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Bad ignition or bad O2 sensor are some of the more common causes.....
Old Oct 27, 2003 | 09:30 PM
rs_boy's Avatar
Already tried to "un fix" it. I'm gonna pop in the Snap On scanner tomorrow and see if I can pull any codes. Thanks for the input. By the way, how much would a O2 sensor run me?
Old Oct 28, 2003 | 10:52 AM
Nixon1's Avatar
Bosch direct replacement, $20.
Just beware what the scanner tells you. If an O2 sensor is bad, usually the computer won't know it. It'll instead throw codes for a mixture problem...usually lean, when in reality you're running rich.
Azrael91966669
25
Jun 20, 2017 04:04 AM
dyeager535
Aug 28, 2015 08:10 AM
CORV3TT3
Aug 23, 2015 11:26 AM
Winchester1094
Aug 18, 2015 10:23 AM
wayshegoes
Aug 17, 2015 12:00 PM
