Engine Help
Old Dec 11, 2000 | 06:08 PM
ShannonA's Avatar
Engine Help
Does anyone know what is the best way to lube an engine that has been sitting up for a while (several years!!!) without messing up anything?????
Shannon Altazan
Little Rock,AR
83 Daytona 500 T/A
89 Firebird V6
Old Dec 11, 2000 | 06:09 PM
B84305-Streetmachine's Avatar
prime the oil pump
Old Dec 11, 2000 | 06:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Shoot some penetrating oil or WD-40 into the spark plug holes; let it sit for a while; then shoot some motor oil in there.
To prime the oil system, you need the tool from Moroso or you can make an equivalent from an old distributor. That works best after the other is done. Use a ½" drill to prime it while turning it over with the starter.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
